I Need hull seam glue ?? Buy where ??
snowxr
V watch your daughters V
Waterford, MI
Last time I purchased it the price was around $400 for the minimum order direct from the manufacturer. It also came in large two part tubes, which required a special air powered gun. My ski is still in one piece, but the glue has leaked water around the bond line into the foam.
Now I'm using epoxy with a carbon thickener.
Motorheads5
Livin the generation gap
ketchikan alaska
I use 3M 8115 panel bonding adhesive it is what body shop's use to glue all these composite body panel's on with! We use it on our lowboy tractor's for Kenworth tipnose panel repair's. It is the same crap I am sure of it, not real expensive and if you do not have the gun just shove it out the end of the tubes with a wood dowel and stir it up. I am sure your local body shop know's all about it. Good luck
hhh
I use 3M 8115 panel bonding adhesive it is what body shop's use to glue all these composite body panel's on with! We use it on our lowboy tractor's for Kenworth tipnose panel repair's. It is the same crap I am sure of it, not real expensive and if you do not have the gun just shove it out the end of the tubes with a wood dowel and stir up. I am sure your local body shop know's all about it. Good luck
Bingo motoman!
3m makes many panel bonds, they even have a SMC, and different resins specific. most are 2 part and need a gun made for the tubes. This is the route i would go, and available at an oreillys, napa or auto paint store if you have one close.
whats the project Frank?
Bingo motoman!
I Cant say yet Matt !! It may not work ,LOL!
Mark44
Katie's Boss
100% one place
p
i use 3m 8115 panel bonding adhesive it is what body shop's use to glue all these composite body panel's on with! We use it on our lowboy tractor's for kenworth tipnose panel repair's. It is the same crap i am sure of it, not real expensive and if you do not have the gun just shove it out the end of the tubes with a wood dowel and stir it up. I am sure your local body shop know's all about it. Good luck
x2
