I guys getting ready to mount a spring in my handpole?
Buckwild12
I'm moved by DASA power!
Ok I got a Blowsion pole spring the other day and am going to try and mount it for this weekend, one problem: I have a lowered Wamiltons bracket, and no pole bolt, it has the dual bolt system. Anyone ever pull this off? Id love some advice. Can I get a section of pipe the Diameter of the bolts to act like a stock bolt? how do you put the spring in with a lowered bracket?
ItsRixter
SoCal Wav Jumping shiznit
Sunny Diego
The walmiltons bracket I have uses a single bolt throught the whole assembly but has a larger spacer on it.
Although slightly different both brackets are intended to be used without a pole spring. Basically the tension of the bolt(s) provides the stiffness to keep the pole up or stationary.
I don't think that will work.
I'd try to fit a piece of pipe over the the nuts on the inside of the bracket like you're saying but those dual bolts are meant to be ran tight. Maybe ditch the wammer bracket and get two shoulder bolts so the pipe you run along the inside isn't sitting on hex nuts?
