Hull SOLD
2019 BAM Gen 2 full carbon hull for sale. Joe widened this hull, extended the rails, and changed their angle compared to the Gen 1 hull to get better cornering. This will flatwater flip and 360 but is also great in the surf or for boat chasing. Never seen saltwater. Only ever been in MI surf.
No damage or repair. The only defect is the small crack up near the pole. This is only in the clear coat and not structural. Otherwise its damn near perfect. Joe did a great job on the layup.
Hull is setup with a 148mm pump shoe and has inserts for a kart tank or a Limited Slip tank. Also has inserts for laydown pipe/waterbox straps.
Hull comes with:
KP Pole - Includes the bracket, pole, spring, bolt, bearing steering (fatbar) and bar pad
2 CF chinpads
CF ride plate
148mm pump shoe installed
CF battery box and strap
Laydown pipe blocks
Footholds and wedges and front foothold
Scupper installed
Hood strap, shock pad, hood latch
3 billet pissers
Superjet style E-box mounts
Custom fit Surlast double lined cover
MI registration and hull HIN tag
I do not want to ship this if possible. I will drive a reasonable distance to meet someone that wants it. I am located in metro Detroit.
For anyone curious, I did a build thread on this. Here: https://www.x-h2o.com/threads/crazy-joes-bam-v2-build.195995/
More pics
