- Lakeside Ca
I'm starting to assemble the heat up old superjet hull i bought and wanted to know if these little hulls are for drainage ? wondering if i should plug them up or what's the deal/or best way to keep them ? I here that SJ get water in the foam and need to drain and that's how you drain them true/ false ? there's also a few pin sized holes on the rail of the bottom of the hull . what should i do with all of them? plug don't plug ? there's 2 on the back of the hull on the bottom and 4 pin holes on the bottom rail of the hull. thanks
