Bought an old Sea Couch that had sank at a beach for an afternoon. Owner got it out and with some help from a local SeaDoo dealer they pickled it. They used kerosene. Everything on the creature stinks like it of course, but a good wash has helped it alot. My question is, what all should I do to the 650SC to unpickle the motor now? Obviously drain the tank. Should I use the 650 drain fitting to drain the crankcase, or just leave it alone since it appearently was sealed this long? Or should I take the plugs out and crank it a while and hope most comes out. I looked to see about installing block off plate for the cc drain, but it's tough to get to in this setup.
Additionally, if I premix this do I have to put a block on the oil injection unit or can I just disconnect the hose and plug it off.
