Super Jet How many more bores?
In theory I think you can go to 84mm and 754cc. There's some debate about sleeve durability at that level of over-bore - some say it's safe, others not so. There was a thread on this issue recently. The debate will probably start again!
Blue
Judging your cheapness
St Cloud Florida
I have seen 84.25mm but dont recommend it. We have gone to 84mm many times. We tested one in Jetmaniac's ski and got 2 years out of the motor before resleeving it.
Sent from my SAMSUNG-SM-N920A using Tapatalk
SXIPro
JM781 Big Bore
Thanks Blue, I've actually been PMing Chris on this, so you'll probably be the one doing this for me. My compression is quite a bit lower in my front hole than my back hole after I had some issues yesterday. It's weird, it seems to still have the same low end grunt, but I lost some top end. I don't really care about top end, so I may just ride it the rest of the season since my season is so short and then send it to you guys in the fall......unless I toast it in the interim. :(
I guess I need to step up to 760 domes as well.
Blue
St Cloud Florida
Yes you will need 84mm domes. Just let me know when your ready and we will take care of it. Thxz
