How hot does the exhaust manifold get?
Waternut
Customizing addict
Macon, GA
I'm trying to find some gasket sheets because factory pipe gaskets aren't cheap and have to be ordered. I've bought and ruined 3 gaskets already this year because the pipe bolts keep rattleing out. I believe my lean condition had a hand in that too...working on it now.
Anyway, I know water runs through that manifold all the time and obviously the exhaust itself is very hot but since I can touch the manifold briefly after a ride without getting burned, it can't be that bad. Would a gasket rated to 350 degrees be sufficient? I can get some 500 degree stuff too but gotta order that too. All the other gaskets at parts store say "exhaust gasket material" but don't give a temperature rating so in my mind...they won't work.
surfjetlouie
R.I.P. 11/27/2008
I have better gasket then Factory $6 each ship to 48 states. Pm me for detail
hhh
stick with louie imo you cant make them as cheap if you figure in all the running around and labor+materials. fast shipper to!!
aranka
usually drunk
Detroit River MI
two things to consider with your bolt issue:
1. are your mani and head pipe perfectly aligned?
2. are you using washer/lockwasher combo and locktite on those pipe bots?
