How hot does it get in the engine compartment?
ger87410
How did I get here?
Fort Worth
Hot enough to melt foam?
I was thinking about putting some closed cell foam on the hood so it doesn't sink if, heaven forbid, the hood ever were to come off.
Would the compartment get hot enough to melt the foam and turn it into a gooey mess on the bottom?
ger87410
How did I get here?
Fort Worth
U know, I've seen 'hood straps' mentioned many times, but never explained.
I've even tried to get people to take pictures of their hood straps, but to no avail.
Until I learn something else, I'm going to stick with what I know.
ger87410
How did I get here?
Fort Worth
No, the search function in here is not my friend. It's very limited, to say the least.
I try it every time before asking a new-to-me question.
Thanx for the link, Eric!!!! I finally know what they are and how they're mounted.
Ericfox
Do it twice?That's DooDoo
I love the search feature.... but I have used it so much I have become a pro at knowing how to find stuff... if you are having trouble with it dont give up... you will get used to it...
Tuscaloosa, AL
when you click search, click advanced, then type in your topic, then on the right it gives you the option of searching individual forums instead of the entire site, this way you can narrow it down.
showmepro1200
ISJWTA Member #007
No I don't but they were the only ones they had as I recall - just the heavy plastic clip type with double slots on both ends to wind the strap ends through.
When I say the WM ones didn't hold, I mean they didn't seem to have enough friction to keep the straps taught at all times. The ones I have now i can pull as tight as I want and they stay.
Oh and I also put round velcro tabs on the backs of the long end side, and the other half of the velcro tabs on the underside of the handpole - that way I can stick them up and (somewhat) keep them out of the way as Im working and when I put the hood back on.
