Super Jet How do you remove copper bushings from the 62t case and flywheel cover that hold the bendix ?
martinez
I noticed that there is a bevel grove spiral inside the bushings. Like the spiral inside the barrel of a rifle. Is there a tool that fits into the spiral to pull the bushing out ?
West MI
If you drop a small washer into the bushing, and use a bottoming tap, you can just run the tap and when it bottoms out on the washer, keep going. It’ll pull the bushing out.
