How can I center the steering
curt248
01 superjet 94 fx1 97 xp
Chicago IL
I just finishe moving the nozzel attachment closer for more responsive steering. I cannot figure out how to center the bars. When I have the bars straight the nozzel is turne a bit to the right.
I notice an a juster near the bars. I loosene it but am not sure how to a just it.
Please help.
Thanks. (sorry the forth letter of the alphabet will not work on this keyboar .
Curt
Shifty
- SuperJet Thursday -
"(sorry the forth letter of the alphabet will not work on this keyboar ."
^^^Thats pretty funny reading it over again.
If your nozzle is angled to the right while the bars are straight you would need to extend your cable "socket" out some. Remove your rideplate and loosen the 8mm jamb-nut behind the "socket" that connects to the ball you just relocated. Slide the spring loaded collar back and remove the socket, unthread it a few turns and reattach to test. Don't go too far. If you run out of room here move up to the turn plate and make adjustments there to.
Dustin Mustangs
uʍop ǝpıs dn
Holland, MI
I leave those jam nuts loose so I can fine tune the steering on the water. It is pretty much impossible to get it dialed on the trailer as just centering the nozzle doesn't seem to do it (at least for me).
Roo
it's all good
This is a lost cause for me...
I throw to the left for most tricks, so I put the nozzle all the way left, put the turn plate on the steering stop, and setup the cable accordingly....
-Andrew
accbr
addicted
Lexington, KY
Doesn't work for me either. Seems like it depends on how you stand on the ski too. My friends ski doesn't go straight when I ride it. Same thing when he rides mine. We always have to have the bars a little off center to go straight. They're perfectly straight when we're on our own skis. He's goofy footed, and I'm regular too.
