sj1million
moto - dirt/h2o
- melboring, Fl
Hey dudes, Im new here and getting into the ski thing more and more!
I have a 2000 SJ with type 8 dry pipe and riva head (not sure what domes are in it) and an MSD enhancer and a few hulland driveline mods. It is stock bore and worn out pretty bad, it only has 135 lbs compression but still runs pretty strong.
Im wondering what the largest bore I can go with these cylinders and what dome I should go with to run pump gas.
I talked to riva and they said I could only go to 82mm bore with these cyl. But I have heard that 84mm is possible. If so what would the recomended piston/ dome combo be? and still run pump gas...
ohh and the little turny knob on the MSD enhancer, what does it do?
