Hooker Impeller Pitch - Cavitation
Ericfox
Do it twice?That's DooDoo
Does anyone have experience with a hooker impeller on a big engine? 870 lamey
Dave recommended a 13/18 hooker impeller for me and its cavitating pretty bad... I cant figure it out since I swear it didnt cavitate the first time I took it out... its really puzzling
I resealed everything and inspected the whole pump... I even sealed the packing with the right stuff to totally rule that out as a cause....
I can only think its the prop pitch or the 86mm nozzle bore... I run the stock cone with it, so i dont see that as being a problem
its going to be tough to compare , I run a ported 760 with a 10/16 hooka and a 771 with 11/17 hooka both with stubby cone and stock nozzle
I am happy with both but I think the 11/17 is cavitating a little too and it might be that my pump seal is not sealing 100% correct, did you shine light in from the intake to actualy see the clearance between impeller and wear ring..I have the feeling that my 11/17 is showing too much a gap just thru the visusal...
Ericfox
So what is next? Is there any good way to figure out if there is a leak at the intermediate housing? it cant leak through the holes around the circle can it? or would it leak around the perimeter of the housing? I guess I could goop up a bunch of 5200 or whatever around the perimeter to see if that fixes it??
Ericfox
The gap is 7-8 thou max... well below the 22 or 24 thou limit whatever yamaha suggests...
