When I took mine off too piant it took a bit of patience, try to find the loosest spot/corner and work it up and out slowly. Once you get a way to get under it I took a exacto knife and cut it carfully away where it was stuck down. be sure to stay close to the hull itself, and minimalize the cuts close to the rubber as not to damage it. Hope this helps. Good Luck!
