Super Jet Hondabond / Yamabond / 1211 cure time ?
Pablo
sqeez bth levrs & lean bk
georgia
How long does it take for that stuff to cure? Can u pressure check ur cases immediately after a rebuild?
Pablo
georgia
I was wondering if u needed to wait the full cure time before u test. That's the safest thing to do I imagine.
Pablo
georgia
Paul Lehr said it skins over in an hour and could pressure test after that happens. I didn't get to that point tonight but if I had the time I would have tried it. I don't see a problem with testing early, before complete cure, since the stuff is supposed to remain pliable anyway. Mine will have passed the 24 hour mark before I can check it but at least Paul provided some food for thought. Thanks for the input boys.
WFO Speedracer
Alabama
My experience has been that testing it at less than full cure yielded not so good results, proceed at your own risk on this one
smoofers
Rockin' the SQUARE!!!!
Granbury, TX
I always wait 24 hours for it to cure on case halves before pressure testing.
I usually only use 1211 on the case halves and then install the rest of my gaskets dry. If say, the intake manifold is leaking then I 1211 the gasket on both sides and retest within a few hours. I have never had a 1211 covered gasket have any problems when pressure testing right after application. However, I always let the case halves cure fully before putting pressure on them.
Pablo
georgia
U guys think the Hondabond adds enough thickness to the base gasket that it needs to be accounted for?
