Super Jet help
"big bore" is a term thrown around for a lot of bore sizes. if it is the stock cyliner than it is over bored. it is bigger than factory bore and about at it's limit of the stock sleeve.
the other time big bore is used is for aftermarket big bore cylinders that usually use a 89-94mm piston. what is the casting number on the cylinder? 61x, 62t, 64u???
