300/440/550 Help with fuel line routing
Hi could anyone tell me which fuel line goes where - my Ski is in the UK and there is not many around to look at any help would be really appreciated
At the moment I am told that the pulse fits to the end of the pump - above that on the picture goes the return and below is the feed
Kind Regards Gary
Help with the fuel lin routing
again "the supply goes to the main body of the carb(on the left in pic). the return goes to the side of the pump body (on the right in pic) and the pulse goes to the end of the pump body (in the middle in pic)."
Hi I have tried that and it wont run - the reason I asked again is someone sent me the attached which shows the end of the pump being the full inlet
Any help would be really appreciated Regards Gary
View attachment mikunibn.pdf carb rebuild.pdf
screaming440
The Old Skool Professor
gary that is correct i told you wrong. sorry i am not sure how i got myself mixed up.
the fuel line goes to the center of the pump, the pulse goes to the side of the pump body and the return goes to the main body.
