300/440/550 help with finding the right pipe for 650sx ?
ct
ok ,here it goes
im looking to buy a factory pipe for a 650sx what factory pipes will fit on my 650 motor and in the hull of my 650sx ? i see a lot of picts with people claiming to have a factory pipe in the hull on the 650's but they do not look like the typical factory pipe that is shown for the 650sx .
are they useing a 750 pipe and if so what is required to make it work???
Thanks
dbrutherford
Parts Whore
Fairmont, WV
Check your PM.
You will need a Factory Pipe Head Pipe.
Then for a 650 SX you can use a
750 SX FPP mod chamber, WB limited chamber, WM Mod chamber, Super Jet Mod or Limited chambers.
Now those will all work but you will have to do some plumbing. Good luck!
