- Stevensville MI
Hello everyone! I'm new to the forum and would like the advice of those of you who are smarter and more experienced than I.
Back in my twenties I used to race my 650sx in the limited class, so I have some working knowledge of standups, but I have no experience with a SJ, other than riding my buddies SN a few times back in the day.
I just took possession of a 98 SJ from my cousin who left it outside behind the barn for a couple of years (he had the cover on it). When I took the cover off of it and opened up the hood, the entire compartment was filled with water. I'm guessing that it had been there for a while... maybe a year + and over the winter.
My son and I just removed the engine this week and tore it down. The flywheel cover was cracked (from ice I'm assuming. We took the head off and were surprised that there was no rust in the cylinders. The motor would turn freely by hand with the spark plugs removed.
When we took the carb and intake off we could see that the crank was covered by standing water.
We want to rebuild this ski this winter with the intentions of making it into a reliable wave riding machine for lake Michigan, and we'd like to do it without breaking the bank.
My planned mods for this winter will be:
Can someone explain the benefits of d-cutting the ride plate (I searched the forums and couldn't find an answer)
As far as the engine goes:
The crank came out easily and besides some mild rust on the bearings, I see no other issues. I don't believe that the cases cracked from ice... Is there anyway to have these pressure checked or tested?
Can I have the crank rebuilt by someone or is there a good source for quality rebuilt cranks?
Stator has a lot of rust on it, do these go bad from sitting in water or is there a chance that they are still good?
For the carbs... Obviously water entered the engine through the carbs and the standing water was pretty much at the level of the carbs when I rescued it. So I'm wondering if there is a resource out there that can test/rebuild them for me if they are still good?
The Ebox... this is my biggest concern! It was under water, probably for a long time. I don't even know where to start with this... any advice would be appreciated.
I'll post some pics tomorrow of the engine and ski so you can get a better feel for what we are dealing with.
On the up side, the ski was free as long as I let him ride it a few times in the summer!
Thanks,
Pete
- reinforce engine compartment
- intake grate
- impellar
- cut pole down
- footholds
- Hydro Turf
- Pipe
- reeds (the factory ones are full of rust)
Thanks,
Pete
