Help weird low end bog after hard hit.
ski is a 96 sj 701
Well I put on a Greater yamaha head. and went to the river to test it out. ski ripped and had no problems at all. Rode it for an hour and then messed up on a nose stab and landed sidways really hard. it now has a bog at 1/4 throttle. i can pin it right off iddle and will rev up fine but when i try just blurping around at low speeds it bogs out and almost dies. I checked the carbs, reeds, head orings, and all hoses and fittings, the e-box is dry... it runs fine on the trailer but when its under a load in the water it bogs. Any ideas? I've had 2 other people look at it and they can't see anything wrong. only other mod on the ski is a R&D pipe. please help. thanks a lot
tried figuring it out for about a half hour. and then today i took it down and messed with it for about a half hour. carbs are off and all cleared out now. going to try a little bit bigger pilot jets. it has 70's in it now.
