help!!sj rail turf install
brett
Ventura,ca
have any of you installed this blowsion rail turf kit? what is the square with a circle cut out for? i thought it came with rubber corner but i guess not. whats the easiest way to install these? i got the glue from blowsion but those corner are gonna be tough. thanks
Use a heatgun to make the turf pliable. Turfing rails is one of the easier turf jobs.
It doesn't come with the rubber bumper because that's a stock part. A $116 stock part, I might add.
W
wydopen
Guest
dosnt using the heat gun make the adhesive wet again???...i thought it needed to be dry and tacky
