Blaster help please!???
uk
hello
right my ski still isnt running right i have a blaster 1 it had msd and a dry pipe on it when i got it was more for top end for round a lake use but want to use it in the surf!! ive took that pipe off and put a protec one on and also added a protec head and now its its not running right!! running realy flat and throughout a days use it will just get worse... ive running it 50/1 wich i think mite be abit rich for it so next tank will be 40/1 and see how that go's but i just looked on the protec web site and when you buy the wake up kit new from them you get a jetting kit wich i guessing i will need to change on mine but i cant seem to find what size i will need...??? can anyone help me please!??
thanks jak
fl
50:1 is fine. 40:1 you will be adding more oil so thats just going to rich in it up even more.
50:1= 1gal gas to 2.56 oz oil... or 6.25 gal gas to 16.00 oz oil
Yea sounds like the carbs. A big change to the motor setup like that would require a rejet for sure. Just use a good oil and 50:1 will be fine. Now would be a good time to look over the motor with a fine tooth comb. In my opinion.
