After I swamped my motor last weekend, I tore it apart and cleaned out all the milky oil\water **** that was everywhere (crank, cases, etc) after doing that and puttint it back together it doesnt fire, it cranks over but just keeps cranking... i checked compression and it reads about 40-50psi both jugs... it fired once and ran for about 5 seconds... but after i killed it , it wont go again...
i even tried puttin gas in thru the plug holes and it wont fire... note - im re-usin the same head gasket as before so could this be the problem? shouldnt it technically still fire with low compression?
and im using the plugs that were in there when it was swamped.. are they fouled ??? there is spark i saw when i checked compression...
