Superjetjim
X-
Looking for some help to check I have the start stop switch wired up correctly? - This is a new JSS built board so the rest of the wiring should be A1, the only bit I needed to do is the Start/Stop and I'm stuck!
I have cabled the Start/Stop as follows:
• Red & Black from Start/Stop linked together and connected straight to ground (used earth backing plate of solenoid)
• Brown from Start/Stop connected to left hand side of solenoid
• White wire from Start/Stop connected to Pink wire from the brain
I have no response to the Stop/Switch when pressed. However if I bypass the solenoid the ski turns over and the plugs spark brightly. Its a solenoid/Start Stop wiring issue I think?
The Solenoid is an MSD one - my finger is pointing at where I have the brown wire connected to.
Is the Brown wire above connected to the correct side of the Solenoid? – it seems both go to earth – perhaps I just need to connect the brown start stop wire to the live side of the solenoid but clearly I don’t want to take and risks and damage anything so thought I would check?
Here's how I have it connected – I am
with electrics so please respond assuming I know nothing when replying!
Grateful for any response/help that may get me on the water this weekend?!:friday:
Jim
Jim
