Help getting ski started
Purge fuel system of any old fuel. Remove spark plugs (and ground them) before turning engine over by hand to check it rotates smoothly. If you have a bore scope, check the cylinders for any obvious issues, particularly corrosion.
Plugs back in, attach good battery, add fresh fuel, prime carb’s with a little fuel down the throats and hit the starter. I would do this outside as I’ve had the odd backfire trying to revive old ‘ski’s and a fireball in the garage is not the best way to start your day.
