Help! bogging in water. fine out of the water??
So i took my ski out yesterday. Started it up before i put it in the water, gave it a couple of braps and shut it down. Then i put it in the water warmed it up for a little while. i started to go and it just bogged down and seemed like it was going to die on me. so i took it back in cuz i thaught it needed to warm up a little more and then i tried again. and once i go past the point of just a little bit above an idle it just bogs down and runs like crap. it almost sounds like its running on one cylinder. it runs just fine out of the water. but wen i put it in the water and put a load on the motor it doesnt want to run right. what could be the problem for this?
agua
FIshing for Stand ups
Seminole, Fl
could be water in the gas
Look into the tank and see if you can see any dark nastey ness in the bottom
agua
Seminole, Fl
it would but you wouldent be able to tell without running it for awhile, when you had it out of the water did you have it on a hose?
agua
Seminole, Fl
I live accross Seminole blvrd from lake seminole
I had the same problem with my ski accouple weeks ago, it was water in my gass because Kawi doesent know how to design a Sun proof gas cap, what kind of ski do you have?
agua
Seminole, Fl
Noice, but ya i would check your gas first, also look into the filter and see if
1 theres lots of crap in it
2 theres cloudy crap in it, suppose both of them are kinda the same huh? haha
alright sorry i found some bogging threads in the search im sorry i should of checked that before i posted this one. but good news took it in to team scream and i wasnt getting any spark from one plug wires so im gonna take it out today and test it. thanks team scream.
