Help a newbie?
djyox
Old school -not by choice
Twincities, MN
Well I know some of you have seen me around, and even more so over on PWCT. But I have been a 550 guy for a while, but I was trying to get out and get into a SJ.
Well now I have, but I got myself into a '90 SN hull with a '94 701 61x blown motor...
I will get pictures and more info as I get into it more. I was looking at beefing the hull up but where my real problem lies is in the motor...
What should I do to get some power out of this? Should I keep it the single carb setup? maybe bump it up to a 46? Its going to be running a protec pipe for the first part of its new life, but because I am going to have this all apart and down to the crank, what should I do to it? what direction should I go with it? I know hardly anything about the yamaha stuff... I had it explained to me a little but I still need to read more I believe...
I will be using this for more of a freeride boat than a freestyle. Big air off of wakes and maybe waves if I get the chance... I'm not looking to do a flat water backflip... but a backflip off of a wake/wave, yeah... so any and all advice would be great...
Thanks a lot guys... I'm pumped I can be apart of the SJ family even if I'm still sporting an old girl...
jeepmark4x4
Backflip, weeee
Marietta, GA.
We'll id start with just rebuilding the motor choose either the pro-x or wiseco piston kits...I prefer wiseco but pro-x is really nice stuff too, make sure the crank is good! leave the single 44 on there for now until you bump your compression, for power add-ons, run a pipe/head/dual carbs...that thing would be pleeenty of power for just freeriding.
djyox
Twincities, MN
Well I guess its cheaper to buy a different crank than to rebuild this one...
I was thinking it would be cheaper to just get new rods and do all the work local, guess not...
What does everyone think of SBT cranks? 1 year warnty, cheaper than anywhere else, even cheaper than personal seller's used cranks...
