HELP ! 94 B1 Blaster, Time For Motor Rebuild ?
Hello every one.
I'm new here and thought I would post this to see if any one here could help me.
Yesterday I was out riding my 94 B1 blaster, I had just fixed my water leak issue, all was good.
I was jumping some 4' waves catching some decent air "Had a Blast" untell I made one last jump and when I landed I gave it some throttle and it about died on me and started running REALLY rough and I could hear the carb making a popping sound, almost sounds like it started running only on one cylinder.
I thought maybe I had sucked up some water in the motor.
So pulled the spark plugs, check the compression, all is good.
When I pulled the back spark plug, I noticed that it was wet "water" so I cranked the motor "with the plugs out" and put my thumb over the plug hole and cranked away.
that seemed to dry the cylinders pretty good.
So after that I put new plugs in and started the motor, and it ran a litlle better but not much, something was still not right.
So I thought, maybe I should check the reeds.
Here is a little background on this to give you a better understanding on my B1 Blaster.
You see when I baught this blaster a month ago it had a Ocean Pro F/A filter on the carb.
This Ocean Pro F/A has four bolt holes with barrel sleaves that the bolts go threw in between the top and bottom F/A housing, well at the time I was buying the blaster from the seller there were only three bolts holding it on and the seller told me that the fourth bolt would not stay tight so he removed it "As seen in the first and second photos below".
Well after I got home from making the 300+ mile trip to buy this blaster I took it out the next day and road it for about 5 hours, ran great.
well two days later I had a problem with a water leak somewhere and check the stock sump to see if it was clogged and checking bad hoses etc... so I pulled the battery box and noticed a long bolt laying back by the drain plug in the transom.
Low and behold it was the missing fourth bolt for the F/A.
So yesterday after it started running bad I started thinking, "Wait ! I found the missing fourth bolt for the F/A, then where could the missing sleave for that bolt be ?"
So I pulled the plugs, dried it out, put new plugs in and started it, it ran a little better but not as good as it should be running, I am still getting that bogging sound from the carb.
So about 15 minutes ago, I thought I would pull the reeds and see the condition of them.
This is where the news gets bad. :scared:
I pulled the intake manifauld to reveal the reed cage.
Well low and behold guess what I discoverd laying inside the reed cage ? "I found the missing fourth F/A bolt sleave.
then I'm jumping around all P/Oed :grumble: cursing at anything and everything.
Along with the missing bolt sleave laying in the reed cage are three little broken pieces of aluminum :shocked: :261: "As seen in the third, fourth and fifth photos.
I can't quit figure out where the broken pieces of aluminum came from, but it appears to be pieces of a piston ?
But why or how would piston fragments end up in the intake side of the reed cage ? I can't see it being possible, because of suction, unless some one "Seller" purposely put that junk in the carb.
I also noticed that the reed chamber in the back was dirty with a wet/aluminum wear mixture, and the reed chamber in the front was clean.
The reeds in the back were dirty like the back reed chamber, and the front reeds were clean as shown in the photos #6,7,8,9 and 10 photos.
The 10th photo shows the rear reeds dirty and the 11th photo shows the front reeds clean.
The 12th photo shows the wet/aluminum wear mixture.
So here I am all P/Off and coming to the conclusion that my riding time is done tell next summer.
I'm P/Off at the :AR15firing::rippedhand: seller for being dishonost/liar and am left with the conclusion that I should remove the motor for a total rebuild, or buy a new motor. :mad:
What would you guys do in this situation ? :feedback:
Photos #6,7,8,9,10,11,12 are shown in the second and third post.
Thanks to any one that can help.
