Super Jet Head gasket....
tor*p*do
Squarenose FTW
NW NC
not real common.
did you have a cooling problem?
was gasket properly installed?
head/deck flat and undamaged?
dfw
I would have to say,
No, to the cooling problem.
Yes, the gasket was installed correctly
No, the head is not damaged at all.
Thick fiber gaskets crush over time, check the head bolts every season and especially after the first ride on a new one.
SUPERTUNE
Race Gas Rules
Clearwater Fl.
Use OEM Yamaha headgasket only... not aftermarket, make sure surfaces are flat, and re-torque after 1st tank, torque the headbolts no less than 23 Ft-Lbs.
