Has anybody shortened the nose of a ski?
I was chatting about this idea with a few guys just this past weekend. seems like it would make sense more than doing the back, as it is kinda like a pseudo rickter.. i guess if you could make the mod to move the waterbox and stuff back and reshape the bottom hull to align with the new angle, maybe deep like a Q8..
Waternut
Customizing addict
Macon, GA
I looked into it quite a bit this last winter and abandoned the idea. I still think it would be awesome but in order to shape and taper everything so that it rides properly, you'd have to refiberglass at least a 1/3 of the bottom of the hull. If you've got a spare hull, I say go for it. Otherwise, there is a huge oppurtunity to make the hull ride 10x worse.
yamanube
This Is The Way
Staff member
Mandalor
Yeah that was my concern, I have a spare hull but dont really want to throw it away if it goes terribly wrong :ugh: I really wanted to section it right in front of the front motor mounts to easily retain the front end design and make it easy to modify the topdeck. I also thought about filling the nose with foam and just start chopping, cut it back and reshape a bit. Would like to take off 4-7 inches from the front and 2-3 in the rear, I don't have a waterbox so would only have to work around my pipe (pretty close to the same location as a waterbox)
Waternut
Customizing addict
Macon, GA
Well something else to think about is this... When you have 2-3" off the back, the nose is rarely in the water anyway so even if the chines weren't made perfect, you may not notice it.
I do like the foam in the nose idea and I would love to see someone chop the nose so you have my support. If I think of any other ideas, I'll chime in.
