Hard starts
new build, started with good running 701 tuned for a factory b pipe. Now Im running Coffman red pipe now.
couple questions: is it normal to have air pockets in the gas line 24 hours after? (clear line, I can see fuel has almost drained from line completely, maybe I need to tighten joints?)
Thinking im running a little rich, in the water restarting you have to hold the gas on just a small amount to restart.
24 hours after am I'm having hard or no start problems, getting spark. Frist week I just swapped the plugs and it fired right up, Im guessing if I do the same again it will start no problem.
