The B2 dry pipe signs off earlier than most dry pipes like a Speedwerx. It makes good power from bottom to top. You will need to prop it to rev quickly, call Dave at impros and tell him this and he will set you up. The pipe will NOT drop in without mods. You need to cut off the mounts that attach to the top of the head and rotate the pipe downward and re-weld on the mounts. If you try to put the pipe on with the stock mounting location, the steering bottom hits and you won't be able to close the hood. IMO, you would be better off getting a B pipe with a mod chamber.
Scottie
