Got my SJ650 running this weekend
So I got the 650 SJ runing this weeked I rode it for 3 days with no drama but yesterday It decided to die while running. If you unplug the lanyard then pulg it back in it fires up and runs grest for about 1 minute then shuts off again then if you unplu/plugin the lanyard it will run again for 1 minute and so on..... I thought it was out of gas but it did it after filling it up also any thoughts???????
Disconnect the start/stop switch at the electrical box. It's a black plug with a white and a black wire coming out. Disconnect that - this will disable the lanyard and the stop switch. You can still start it just fine.
Ride it around like that and see if your problem is gone. If it is, your start/stop switch assembly has problems. I's a common occurence. They can be rebuilt, or you can just try to clean it yourself.
Be aware that you cannot shut your ski off with your normal button/lanyard while it's disconnected. You'll have to choke it or prime it.
