Custom/Hybrid going to do 300sx build and i need help!!
i got a 300sx complete ski with broken motor mounts. he says it ran last year but whatever im going to put a diff motor in it... im trying to see if its even worth it these days... im hoping to get a 650 or 750 motor and a pipe and carb but how much work and money does it take to switch?
WFO Speedracer
Alabama
It does not require a lot of money but it is a lot of work, if you are not familiar with using epoxy resin and glass cloth don't attempt it as a pump swap is mandatory as well as strengthening the bulkhead area.
WFO Speedracer
Alabama
You have the same pump as a 440, its small and is a high RPM pump, it works well in nothing except a race ski that turns a zillion RPM's been there done that have the t-shirt
