Glassing in tubbies
Wisconsin
Thinking about glassing on my tubbie 2's to my squarenose. Anyone have pictures of how they did theirs? Should I glass just the edges or place fiberglass matting over the entire tubbie?
I haven't glasses any on before but I'd probably glue them on with 4000 or 4200 and lay mat along the edges with about a 1/4 to 1/2" overlap of glass on each side, sanded as smooth as possible.
Wisconsin
Not sure if anyone is even looking at this thread, but I'm hoping for opinions. Thinking about not even using fiberglass mat, just epoxy resin mixed with 404 to thicken it up and make it smooth around the edges.
PNW
I used thickened epoxy but needed to screw them in "temporarily" to hold them against the hull until the epoxy set. Then i removed the screws and filled the holes with epoxy and ran a bead of epoxy around all of the edges and blended them into the body.... My ski was completely apart though so it made it easy to work from both the outside and inside...
Wisconsin
Yes my ski is completely tore down because I'm prepping it for paint and glassing these tubbies in is my final step. What you did seems like the easiest way of doing things
