glass/carbon laminate/hull sucking water without gelcoat?
Christian_83
Xscream
Denmark
Hi guys.
A friend of mine told a story about his friend who is a boat mechanic, they sold a fiberglass race boat (sailboat) and weighed the boat before it hit the water.
After a few races they weighed again, and they said it gained 300kg/660bs (i don't know the size of the boat) And the reason for this should be, than the hull had not been given gelcoat and therefore had sucked water and added the weight. I think it sounds a little strange or what?
DAG
Charlotte, NC
I'm no composite guy but shouldn't all fibers be 100% saturated in a binder be it resin/vinyl/polyester
PA
Who makes a boat and sticks it in the water without some kind of coating on the outside? Whether gelcoat or paint or whatever? Was your friend drunk when he told this story? Maybe after they put the boat in the water, they docked it, and loaded it with a couple kegs of beer and some gear.
Vumad
Super Hero, with a cape!
St. Pete, FL
Really the fibers don't saturate. They are glass. You seal the glass inside of the resin. The resin does not go inside of the glass.
Sanding the gelcoat off and not resealing will leave exposed fibers. I have a ski that I sanded the gelcoat and left exposed to the elements for years. It got all fuzzy as the smc started to break down. Had to sand off all of that and reseal it. The areas that still had gelcoat on them where smooth and just fine.
