Gasket Sandwich
ski4
gonzo
cleveland
I am installing a riva reed spacer on a 62 t set up
just in reading the install instructions on riva's site i am not sure if i still need to use the
GASKET, PLATE, GASKET set up that is stock on the manifold.
it sounds like you just put the new riva type gasket on the case, the spacer, a new intake manifold gasket then the manifold
does this make sense ( i hope)
is that metal thin plate something that needs to be in the mix?
