Run another tube so you can keep your siphon line. I got mine off mcmaster for like $6 (low quality aluminum 3/8" tube) Either way you will have to tap the pump for a second fitting, which is problematic because the fx1 pump doesn't have any meat for a second hole. I ended up trimming the pipe thread down to about a 1/4" long on the elbow so it wouldn't protrude into the pump and used some JB weld to help secure it.
For the second aluminum tube i drilled a 3/8" hole on the pump side. Then sharpened the edge of the tube to cut through the foam. I put the opposite end of the tube into the chuck of my drill and fed it through to the bulkhead. It's pretty easy to get a straight shot, just keep your eye looking down the tube and keep it straight. Then just spin the
out of it while pressing it up against the bulkhead for a little while. Stick your hand on the bulkhead and feel for the hot spot. Mark it, drill it, and pull the tube through. Cut off excess and epoxy it in place.
