FX-1 Fx1 Aftermarket Water box Info
dfw
what water box are you running? is it worth putting one in if you are only running a pipe? why do some guys use superjet RN water boxes?
Use the stock box until it blows up, it will on the first good after fire. Then get a stock RN box. All aftermarket boxes are annoyingly loud and do nothing for power. A TDR will also eat two holes through your hull when the padding comes loose.
95FX1
brrrrraaaaaappppppp
i use the SJ metal box and Gas tank...
it seems to fit better with my pipe...the height of pipe exit and metal box angled inlet seems to match for me just right...
seems to anyway?!?!
