Shrivel
Requires therapy.
- Acworth, GA
at the start of the season i installed a b pipe on my basically stock RN. i rejetted the carbs with the factory jets (135) and set the screws at fp's recommended starting points. i have been chasing a problem ever since. it appears to run fine at high speeds, there's no hesitation going from half to wot, but it bogs down at the bottom and often won't start after it gets warm without choke. choke it and it starts okay. here's what i've tried:
- messed with the high speed and low speed screws. has some effect but no remedy.
- replaced the crusty, streched carb diaphragms.
- cleaned the carbs.
- blew out all the fuel lines
- sealed up the intake gaskets really well
nothing's fixed it. any other ideas? the ski ran great before i installed the pipe.
