N3vrSat1sfied
Military Member
- Fort Worth, TX
Let’s talk fuel tank vents.
The factory Yamaha ones are one way but with a pop off. The aftermarket seem to never pop off and allowing the tank to build pressure past the needle and seat causing fuel to flood the engine.
This year with my skis on the dock I’ve noticed this with two different engines, different carbs, different tanks etc.
What’s the consensus, just use the oem fuel tank vents? Or do I have some other issues like weak springs? I did check pop off both times and it has been good. Last time I replaced the tank vent and put new springs on and didn’t have an issue afterwards.
