Custom/Hybrid fuel solutions
THRUST
ThrustInnovations.com
These are new thrust innovations fuel tank setups available we have 1,2,3 gallon setups with billet fuel fill and single or dual fuel line apllications .3 gallon in stock will work with powerfactor pipes as well
$225 for dual fuel line any gallon
$215 for single any gallon
just billet fuel fills for oem mount $90
smusleh
JetSkiExtrm
MI
What are the demensions of the 2 & 3 gallon? I want to make sure it will fit. Also, is there are special mounting plate or bracket that it uses or do you just utilize the rubber OEM tank straps?
carbonjet
USA
I would like to know if the 3 gallon tank will fit with power factory dry pipe in a Matrix hull. I would assume if it fits in the Rickchitz it will fit in mine.. I want one of those gas caps too, nice work! :beerchug:
