Super Jet Fuel Pump Assembly
I just want to make sure I got this right before I install these carbs back.. It's Mikuni 38 SBN carbs and im concerned about the fuel pump side. Alot of different gaskets/diapghrams in the genuine rebuild kit.. I have it assembled in this order, starting with the carburetor base:
carb base
o-ring
black diaphragm
fuel pump body
round o-ring
clear diaphragm
paper gasket
pump cover
Also on the fuel pump body is some clear check valves with rubber grommets. They both sit on the machined surface of the pump body and not the casting side.
