Fuel mixture change when ski is rolled
MMor101
Very nice, How much?
Skippack, PA
On my 61x blaster if I try side mounting it from the intake side it will load up. On the other hand if I lean it too far over on the exhaust side it will be starved of fuel. Is this normal? I'm running a single 46mm SBN. Currently its rich on the bottom. I'm waiting for my pop off spring in the mail.
WaveDemon
Not Dead - Notable Member
Hell, Florida
when you install your spring check the needle and seat. it would be best to use a pop off tester bot if you don't have one look very closely at the black tip of the needle. if there is any mark on it at all you need a new one.
SXIPro
JM781 Big Bore
Can you explain what the mark on it indicates? I am clueless on this whole pop-off deal. Thanks
Ericfox
Do it twice?That's DooDoo
on the tip of the needle it will wear... the ones I have seen have a little ring worn on the tip of the needle... if it gets bad it will will not seal right when the spring pushes it down to seat... right?
WaveDemon
Hell, Florida
yep, a little ring wears into the rubber tip.
