SXR fuel delivery issue
Zerfman34
M.D. in the works...
Troy, MI
Hey guys I'm sure this is something simple but I just can't figure out why my carbs aren't letting any fuel in. engine starts up fine with primer, but just burns the primed gas and can't get any more fuel from the carbs.
I have a single-carb primer hooked up between fuel switch and carbs. (functional)
when I blow in the return line to pressurize the fuel system, expecting gas to come spurting out of the "return line out" on the front carb, I get nothing. The gas is getting to the carbs, as I pulled the gas line into the carbs off and made a big mess. Is there something in the carbs that I'm missing that might be preventing gas from getting where it needs to be? I should expect to see gas coming out of the return line out from the carbs with the fuel system pressurized with no leaks, right?
The carb's internal fuel filter may be plugged.
Sent from my DROIDX using Tapatalk
Zerfman34
Troy, MI
I'll check that. Shoulda mentioned that I just got them back from Harry at Group K with a sleeper kit. I'll give him a call too once he opens up out there.
