- Midland, Ontario, Canada
having a little bit of an issue here and hope you guys can suggest what to do next.
I am running a stock 62t/61x with stock mik 38's...I just got done hooking everything back up, shot some premix into the carbs and it fired right up, seems to run fine but cuts out once fuel is used and does not pull any more gas from the tank. All lines are still dry and I am pretty sure they are hooked up properly. Any suggestions??
