Mike W
Infidel
- North Florida
1994 B1, stock other than a oil injection block off, primer kit, R&D rideplate and intake grate. The hull is very solid but the top deck is faded and has slight gelcoat crack on the right side of the top deck (pictured). I replaced the pump and transplanted a freshwater motor from a 1994 WR3 that has 142/145 compression. The carb was replaced with a minty carb I was holding on to. All the fuel lines were replaced as well. Located in Starke, FL. $1800.00
