Front Exhaust Hose???
2lick
Brap!!!
Limerick, PA
What I used last year sucked....
I hear most guys use a radiator hose from local stores... none of mine had in stock last year...
anyone have a part number so i can order one.....
Thanks,
-NICK
DAG
Charlotte, NC
what did you use last year?
their are a few people on here that have busted up seepoo's i was going to get a hose from one of kurt's ski yard.
2lick
Brap!!!
Limerick, PA
last year i sued to short pieces that they had in stock and tied them together witha piece of aluminum pipe in the middle... they kinked to bad at the joint though and it was like a 1.5 inch opening....
thanks for the part number!!!
THRUST
ThrustInnovations.com
get a good year radiator flex hose it is part #53224 i believe i will let you know for sure tomarrow .it is about $28 or if you want to spend a little more go to a silicone hose or hydrolic hose companies usually have the and get a slicone flex hose 1 1/2 inch by about 16 inch those are the best to get and are around $40 but either will do the job just fine .
I took the ski to O'riles and asked to see the universal radiator hose and he took me in the back and I picked one out ran outside to see if it was long enough and went form there. O'riles adn AutoZone have all the radiator hose hanging so that you can see them. You can bend a piece of coat hanger and buy a prebent one for a car that might work. I found an exact prebent pipe that will work from the blaster pipe to the waterbox but it was 1.5 inch I needed 2.
