Hi,,I'm planning to get a 701 or 760 engine to replace the 650 in my square nose,,,but I'm a newbie to this so do I have to replace more stuff,,,like midshaft,pump???
it's mostly bolt in and go, the 760 has larger exhaust manifold bolts though. You can use the 650 electronics and flywheel, the only difference between the 6m6 (650) electronics and the 61x (single carb 701) is a lower rev limiter in the cdi.
