FP water screw removal techniques
NVJAY775
My home away from home.
Well as you guys can guess I have 3 stuck screws. I've tried a few things, but haven't had any luck yet. Luckily the bottom and middle screws are closed. But I would like to be able to still adjust the top screw.
Things I have tried...
PB Blaster overnight without heat and a allen wrench.
Then double nutting without heat with overnight PB Blaster.
Heated pipe and tried double nutting nada.
Let cool and then tried heating screw with double nut still on and nada.
Any other techniques you guys have used that worked?
Next is a stop by the machine shop and see what they can do.
Send it to Art at Jetworks, is another idea.
Or look for a head pipe with functioning screws.
