formula for mm of port measument to port duration?
With different cranks I know there is no perfect answer here,but even a typical answer would help.
For every mm you lower the transfer port height with sleeve placement ,how many degrees does it change the transfer port duration on a long rod 5 mil stroker?
I have a old cylin that has 130 transfer port duration measured with a degree wheel,on this crank,rod,spacer plate setup.I have another that has transfers port 3.5 mill lower,but it has BB sleeves that require the cases to be cut to fit so I could measure with a degree wheel.dont want to do this just yet.What will the approx transfer port duration be on the this cylin?
